FireStormGS
- Jul 24, 2001
Today the right channel on my headphones totally died. I know it because of the repeated movement around the jack because it would cut in and out as i moved only that area. So I cut it open thinking it would just be normal wires and I would be able to solder a new jack on the end. Inside I found this.
It's like nylon cord wrapped with very fine wires with no insulations between them. Can I just solder those and it will work fine?
