I cannot remove my front intake filters on my P180B.
The case manual says:
"There are two tabs on the filter. Use both of your hands to press the tabs downwards. Lift it up and slide it towards the top of the case to remove the filter."
When the say "Lift it up" I think they're referring to the filter. I'm having a hard time lifting the filter up when both my hands are pressing the tabs down.
When I take one hand off one a tab to try and lift the filter up it won't budge.
How do you get your air filters off your P180B? Would you recommend leaving them off for better airflow?
