help! Reliable source for voltages - BIOS?..
luigidon
help !!....
getting really confused over what source I should trust for my voltages.... got two sources - the bios and Nvidia control panel - but they show different voltages for the same component e.g. cpu core
on top of that Everest and CPU-Z reports a differet voltage as well... ?!?!?
knowing my luck I will base any increase in voltage on the wrong reading and either blow something or not get as finely tuned as possible - and i'd hate that :)
Should I always change by the BIOS?
start prime95 or any app that will put your CPU to 100% load and then start cpuid or hardware monitor and watch the vcore voltage, thats your true voltage.
for my 9650 I have to set it to 1.5 in vios for 4ghz. In windows idle its 1.43v and then under load its 1.37v
