So I'm finally going to pick up a 79XX series card, but I'm considering whether or not I should go the 7950 or 7970 route, and which manufacturer to go with. In the past I've always like XFX. It'd be mainly used for gaming of course, and although I'm currently only using a 1080p Samsung TV as a monitor, I do plan on picking up a much high res monitor in the future (and I like maxing out as many settings as possible).
I'm considering whether or no to go with a basic 7970 or a "deluxe" 7950 (such as the Sapphire 7950 that has two fans and apparently OC's like crazy). But then even with OC'ing the 7950 will never have the shader count or memory bus that the 7970 has, so I'm torn. It's apparently like a $60 difference.
