Carnival Forces
- Feb 9, 2003
the problem:
my computer keeps randomly restarting, usually when i try to run something involving video (like watch a movie or play a game)
the specs:
Chaintech ZNF3-150 motherboard
Radeon 9800 PRO gpu
Athlon 64 3200+ cpu
2x512MB Corsair ram (DDR 400)
some crap Audigy sound card
a netgear wireless NIC
DiamondMax Plus 9 200GB SATA HDD (model number 6Y160M0 i think)
a cd burner
a dvd burner
what i've tried:
at first i thought it was my HDD so i bought a Seagate HDD (just some crap 5k rpm ATA 20 GB) from compUSA--no beef, restarts still occured
so i've disconnected that hard drive.
then i thought it was the video card, so i took out the 9800PRO and put in a 7000 (PCI) that i knew worked--still screwing up.
so the 9800 is back in.
i know it's not the RAM, because back when it was stable i Prime 95'd it and i passed (which means it's not the CPU either).
so, unfortunately, i think it's my good-for-shit motherboard.
however, other odd things that happen: my BIOS won't recognize my hard drive disk, i can't seem to set one disk as a master (neither the ATA, which it does recognize, nor the SATA, which it doesn't)
so IDE1 and IDE2 have one master each--the first my CD-RW and the second my DVD+/-RW (IDE2 used to have the ATA as a slave, but i took that drive out)
the only work-around i have is to let it rest from its (sometimes) infinite reset cycles and then try again. resetting the BIOS through the BIOS or on the motherboard (through the red jumper) doesn't seem to do anything constructive.
odd though, sometimes when it restarts it tells me "Resetting CPU frequency! Systme now in safe mode! Press F1 to continue DEL to enter setup"
^--i have no idea why it needs to reset my CPU's frequency since i don't overclock
i'm fairly certain it's not a virus (i use AVG Free) or spyware (i use Adaware and Spyblock) but, i am backing up (slowly oh so slowly) all my shit onto DVDs in the hopes of an eventual reformat.
btw, if anyone can find drivers for my hard drive (the DiamondMax Plus 9 200GB SATA 6Y160M0 thing) that would be awesome--not only have i misplaced mine, maxtor.com sucks a bunch.
bah, my well-being is in your hands. don't drop me.
the specs:
Radeon 9800 PRO gpu
Athlon 64 3200+ cpu
a cd burner
a dvd burner
what i've tried:
