Help! Raid advice needed.
Mcavity
Ok looks like its about time for me to enter the world of RAID.
However I'm a bit confused with the best way to do this with my particular hardware setup.
My "server" is the following configuration.
IDE
Drives
1 - 120 gig boot drive
3 - 500 gig [seagate] drive
SATA
2 - 750 gig segate drives
What would be the best way to get most performance and redundancy out of this?
Umm to be honest with that setup, you're not ready. The only thing you can do is setup two Raid1 arrays. a 2 drive 500GB and a 2 drive 750GB.
ok it looks like if i get another 750 gig drive I should be able to set up 2 raid 5 arrays.
Since xp only does raid 5 as a hack.. any recommendation on cards to use?
