Ok, I've read the HOWTO by graysky and attempted the OC myself, first time.
I got it to be at 3.0 ghz.. But how do I know whats my limit and when to stop? I want to be able to run at the best speed that I can and maintain a good overall temp.
These infomations are taken from EVEREST Ultimate Edition. I'm not sure what infomation to supply so I hope this takes care of it..
I will post a ss up soon.. The prime95 test is running at the moment.
Field Value
CPU Properties
CPU Type QuadCore Intel Core 2 Quad Q6600
CPU Alias Kentsfield
CPU Stepping G0
Engineering Sample No
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPUID Revision 000006FBh
Core Voltage 1.288 V
CPU Speed
CPU Clock 3006.0 MHz (original: 2400 MHz, overclock: 25%)
CPU Multiplier 9x
CPU FSB 334.0 MHz (original: 266 MHz, overclock: 26%)
Memory Bus 400.8 MHz
DRAM:FSB Ratio 12:10
CPU Cache
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ASC, Full-Speed)
Motherboard Properties
Motherboard ID 09/06/2007-P35-W627DHG-6A79OA1BC-14
Motherboard Name Abit IP35 Pro (3 PCI, 1 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Chipset Properties
Motherboard Chipset Intel Bearlake P35
Memory Timings 5-5-5-15 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM1: G Skill F2-6400CL5-2GBPQ 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
DIMM3: G Skill F2-6400CL5-2GBPQ 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
BIOS Properties
System BIOS Date 09/06/07
Video BIOS Date 11/08/07
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message
DMI BIOS Version 6.00 PG
Graphics Processor Properties
Video Adapter nVIDIA GeForce 8800 GTS 512
GPU Code Name G92GTS (PCI Express 2.0 x16 10DE / 0600, Rev A2)
GPU Clock (Geometric Domain) 648 MHz (original: 650 MHz)
GPU Clock (Shader Domain) 1620 MHz (original: 1625 MHz)
Memory Clock 972 MHz (original: 972 MHz)
Field Value
Memory Module Properties
Module Name G Skill F2-6400CL5-2GBPQ
Serial Number None
Module Size 2 GB (2 ranks, 8 banks)
Module Type Unbuffered DIMM
Memory Type DDR2 SDRAM
Memory Speed DDR2-800 (400 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 400 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 24-51-3-6-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-10 (CL-RCD-RP-RAS) / 16-34-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
Memory Module Manufacturer
Company Name GSkill International Enterprise
Product Information http://www.gskill.com/indexen.html
Field Value
CPU Properties
CPU Stepping G0
CPU Speed
CPU Multiplier 9x
CPU Cache
Chipset Properties
BIOS Properties
Award BIOS Message
Field Value
Serial Number None
Module Width 64 bit
Memory Timings
