help! psu ok with this card?
themandude
Hey guys I am about to make a order and just need your opinion. I am buying the GPU
ATI X1950XT 256MB DDR3 PCI-E w/VIVO & DVI-I Sapphire
http://a-power.com/product-2715-354-2
And the PSU
Enermax 485W w/Noise Taker II SFMA(24+6) EG495P-VE
http://www.a-power.com/product-2036-342-2
I am wondering if this combination is ok? Is this PSU properly powered for my card? I mean does anybody have this combination? Thanks for the help, I am ordering in the next few min please respond.
I can vouch for the Enermax, I personally used the that exact model for a couple of years and never had a single problem. It will have plenty of power for that 1950xt, and more.
And btw, arent the coolermaster extreme, the cheapy psu line. Thought the Real power line was there quality ones.
And the PSU
Your PSU will be fine. I'm running a 425w Noisetaker with a Q6600 and a 8800GTS - no problems what so ever.
dam I wish I got a reply sooner, I got nervous about that PSU that it wasn't good enough So I went out and bought a 95$ OCZ gamer PSU :(
Aw sheesh the OCZ units are known for their high ripple. As long as you don't overload it, it should be fine.
