I need help!
Today i was on my computer, old IC7-G with 2.4 OCed at 3.3... my surge shut down and cut the power to my 2 monitors, printer, cable modem, and whatever else...
I went to the basement and saw that one of the switch was popped to off position. and turn it back into on position and when i turned on my PC....
During post, it detects my CPU, and... shows the speed, den shortly after, it freezes at
CPU Typ... It doesn't even type in the Missing "E" in Type.
Reset CMOS and tried unplugging some stuff, IE, HD and What not... but No go.
PSU issue? I pulled out the CPU, no visible damage, and no water leak from cooling either.
confused!
Thanks in advance...
And if.. i need to replace, i wanna get a new mobo, ram, intel core 2 duo and vid card... suggestions?? of combos that are good??
confused!
