Help! Problem with ps2 port!
Thanatos.
Ok so i was cleaning my case out and when i brought my computer back up stairs and plugged it in first it wouldn't power up so i turned the PSU off and made sure i had it plugged in correctly and then tried it again and it booted but now whenever i have my USBtoPS2 adapter plugged in it doesn't work and the board emits a quite high pitched squeak sound. Ive made sure everything is plugged in correctly and nothing is making contact with the board I tried my roommates ps2 adapter, same thing. And my friends ps2 keyboard doesnt work on it either. Nothing else seems to be wrong any ideas on what the problem might be? System is in sig.
On some boards you can blow the port if you plug in a PS/2 device while the system is on. The PS/2 ports are not hot pluggable like USB is.
Also check for a bent pin in the connector.
Something might have come loose internally while you were cleaning.
