Help ! Problem with HPw2408h
davidoff
Ok, so I had my crt plugged to the vga out of the graphics card, now I bought this HP tft and it only has either vga or hdmi. Because my card supported dvi, I bought a dvi-to-hdmi cable to connect it to the monitor. It works well, but when I leave it for a few minutes and the monitor "goes to sleep", when I try to turn it on again it just says " hdmi port: no input " and goes back to hibernating. Then I have to either plug it out and plug the cable in again or reboot the pc. Is there some setting I need to change ? My gpu is a X700 pro and I'm using vista.
Thanks in advance
