Help - problem with downloading
Vette5885
I haven't been folding since May (My room didn't need the added heat during the summer)
But I think its about time to start again (I can now use the added heat!)
I downloaded the 5.04 client - but it won't properly download a core. I keep getting:
[20:44:13] Verifying core Core_78.fah...
[20:44:13] Signature is _NOT_ valid on given file.
[20:44:13] Failed to verify core
[20:44:13] + Error: Could not extract core
[20:44:13] + Core download error (#6), waiting before retry...
Could it be that I'm running XP64?
Try stopping service. Delete evertything but console5.04 and config file then start up again
# Windows Console Edition #####################################################
Folding@Home Client Version 5.04beta
http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\FAH
Service: C:\Program Files (x86)\FAH\FAH504-Console.exe
Arguments: -svcstart
Launched as a service.
Entered C:\Program Files (x86)\FAH to do work.
[21:00:51] - Ask before connecting: No
[21:00:51] - Use IE connection settings: Yes
[21:00:51] - User name: maloprie (Team 33)
[21:00:51] - User ID: 28EAF0610A875D07
[21:00:51] - Machine ID: 5
[21:00:51]
[21:00:51] Work directory not found. Creating...
[21:00:51] Could not open work queue, generating new queue...
[21:00:51] + Benchmarking ...
[21:00:55] - Preparing to get new work unit...
[21:00:55] + Attempting to get work packet
[21:00:55] - Connecting to assignment server
[21:00:55] - Successful: assigned to (171.65.103.162).
[21:00:55] + News From Folding@Home: Welcome to Folding@Home
[21:00:55] Loaded queue successfully.
[21:01:29] + Closed connections
[21:01:29]
[21:01:29] + Processing work unit
[21:01:29] Core required: FahCore_78.exe
[21:01:29] Core not found.
[21:01:29] - Core is not present or corrupted.
[21:01:29] - Attempting to download new core...
[21:01:29] + Downloading new core: FahCore_78.exe
<EDIT--- Downloading....---EDIT>
[21:01:30] Verifying core Core_78.fah...
[21:01:30] Signature is _NOT_ valid on given file.
[21:01:30] Failed to verify core
[21:01:30] + Error: Could not extract core
[21:01:30] + Core download error (#2), waiting before retry...
Still nothing.
Network works fine for everything else.
Could it have something to do with the FahCore_78.exe being different from Core_78.fah?
It was set to 1 - I thought that it might fix it. Hasn't changed anything (I'll change it back)
Config File:
[settings]
username=maloprie
team=33
asknet=no
bigpackets=yes
machineid=1
[http]
active=no
host=localhost
port=8080
usereg=yes
[power]
battery=no
[core]
checkpoint=10
I forget, what is usereg=yes for?
Are you editing the config w/ notepad?
Yes, I am using notepad
I'm not sure what its for either. This is the config file that the install spit out - I only changed the machine ID, thinking that maybe the servers had remembered the IDs I had for my original 4 boxes, and that somehow it screwed it up.
Editing in notepap can screw things up (can't image is here..)
Try deleting everything put the console.exe. Start>run> console.exe -config and pop back in all the info you need.
Generally kicking the client (just redoing) fixes almost any issue.
Why it's downloading the core but saying is invalid core is kinda odd....
From past experience, people have had problems editing the config files using notepad. The only reliable way to edit your config is to do it using the -configonly switch instead.
That is wierd.
I thought that I originally ran the program without editing the config file - I guess not.
Deleting everything and re-running the config did the trick.
Thanks a lot.
Vette5885 said:
hey, I'm allowed to make a typo every now and then.
not around here....i should know ;)
You are all a bunch of grammar nazi :p
actually... I changed mine to match yours... I thought I was wrong....
Hey guys, I'm having this problem again - now on two computers. Here is my MediaCenter:
--- Opening Log file [October 28 17:30:40]
Launch directory: C:\Program Files\FAH
Executable: C:\Program Files\FAH\FAH504-Console.exe
[17:30:40] Configuring Folding@Home...
[17:30:57] - Ask before connecting: No
[17:30:57] - Use IE connection settings: Yes
[17:30:57] - User name: maloprie (Team 33)
[17:30:57] - User ID: 5185453971524FDC
[17:30:57] - Machine ID: 1
[17:30:57]
[17:30:57] Work directory not found. Creating...
[17:30:57] Could not open work queue, generating new queue...
[17:30:57] + Benchmarking ...
[17:31:00] - Preparing to get new work unit...
[17:31:00] + Attempting to get work packet
[17:31:00] - Connecting to assignment server
[17:31:00] - Successful: assigned to (171.65.103.158).
[17:31:00] + News From Folding@Home: Welcome to Folding@Home
[17:31:00] Loaded queue successfully.
[17:31:02] + Closed connections
[17:31:02]
[17:31:02] + Processing work unit
[17:31:02] Core required: FahCore_82.exe
[17:31:02] Core not found.
[17:31:02] - Core is not present or corrupted.
[17:31:02] - Attempting to download new core...
[17:31:02] + Downloading new core: FahCore_82.exe
[17:31:02] + 10240 bytes downloaded
[17:31:02] + 20480 bytes downloaded
[17:31:02] + 30720 bytes downloaded
[17:31:02] + 40960 bytes downloaded
[17:31:02] + 51200 bytes downloaded
[17:31:02] + 61440 bytes downloaded
[17:31:02] + 71680 bytes downloaded
[17:31:02] + 81920 bytes downloaded
[17:31:02] + 92160 bytes downloaded
[17:31:02] + 102400 bytes downloaded
[17:31:02] + 112640 bytes downloaded
[17:31:02] + 122880 bytes downloaded
[17:31:02] + 133120 bytes downloaded
[17:31:02] + 143360 bytes downloaded
[17:31:02] + 153600 bytes downloaded
[17:31:02] + 163840 bytes downloaded
[17:31:02] + 174080 bytes downloaded
[17:31:02] + 184320 bytes downloaded
[17:31:02] + 194560 bytes downloaded
[17:31:02] + 204800 bytes downloaded
[17:31:02] + 215040 bytes downloaded
[17:31:02] + 225280 bytes downloaded
[17:31:02] + 235520 bytes downloaded
[17:31:02] + 245760 bytes downloaded
[17:31:02] + 256000 bytes downloaded
[17:31:02] + 266240 bytes downloaded
[17:31:02] + 276480 bytes downloaded
[17:31:02] + 286720 bytes downloaded
[17:31:02] + 296960 bytes downloaded
[17:31:02] + 307200 bytes downloaded
[17:31:02] + 317440 bytes downloaded
[17:31:02] + 327680 bytes downloaded
[17:31:02] + 337920 bytes downloaded
[17:31:02] + 348160 bytes downloaded
[17:31:02] + 358400 bytes downloaded
[17:31:02] + 368640 bytes downloaded
[17:31:02] + 378880 bytes downloaded
[17:31:02] + 389120 bytes downloaded
[17:31:02] + 399360 bytes downloaded
[17:31:02] + 409600 bytes downloaded
[17:31:02] + 419840 bytes downloaded
[17:31:02] + 430080 bytes downloaded
[17:31:02] + 440320 bytes downloaded
[17:31:02] + 450560 bytes downloaded
[17:31:02] + 460800 bytes downloaded
[17:31:02] + 471040 bytes downloaded
[17:31:02] + 481280 bytes downloaded
[17:31:02] + 491520 bytes downloaded
[17:31:02] + 501760 bytes downloaded
[17:31:02] + 512000 bytes downloaded
[17:31:02] + 522240 bytes downloaded
[17:31:02] + 532480 bytes downloaded
[17:31:02] + 542720 bytes downloaded
[17:31:02] + 552960 bytes downloaded
[17:31:02] + 563200 bytes downloaded
[17:31:02] + 573440 bytes downloaded
[17:31:02] + 583680 bytes downloaded
[17:31:02] + 593920 bytes downloaded
[17:31:02] + 604160 bytes downloaded
[17:31:02] + 614400 bytes downloaded
[17:31:02] + 624640 bytes downloaded
[17:31:02] + 634880 bytes downloaded
[17:31:02] + 645120 bytes downloaded
[17:31:02] + 655360 bytes downloaded
[17:31:02] + 665600 bytes downloaded
[17:31:02] + 675840 bytes downloaded
[17:31:02] + 686080 bytes downloaded
[17:31:02] + 696320 bytes downloaded
[17:31:02] + 706560 bytes downloaded
[17:31:02] + 716479 bytes downloaded
[17:31:02] Verifying core Core_82.fah...
[17:31:02] Signature is _NOT_ valid on given file.
[17:31:02] Failed to verify core
[17:31:02] + Error: Could not extract core
[17:31:02] + Core download error (#2), waiting before retry...
This is happening on both my mediacenter PC and my main computer. My testing machine will be done with a WU soon - I hope that doesn't have a problem too.
I've deleted everything in the folder and reconfigured it - but still doesn't work.
Could one of you guys maybe send me the core? The other computer with this problem is trying to get the same core (82)
