I've found a solution, please see this post later in the thread: http://www.hardforum.com/showpost.php?p=1029513511&postcount=9
Hey Guys,
I used to have an ASUS A8N-SLI [oh, how I miss it], but when I installed a new XFX 6800GS video card it was either too much for my Enermax 350W PSU to handle or I jogged it loose when moving the computer and shorted something out. In any case, the ASUS motherboard died.
My Wife is completely dependant on our computer, so I sort of had to scramble to get a new PSU and motherboard [to be safe]. The new PSU didn't correct things, but the new motherboard did... well, sort of. [My new PSU is a Enermax Liberty 500W btw, and it is wicked cool]
Anyways, after struggling for a long time I managed to get XP installed. Huge problems getting it to boot from CD and install properly. After the install, I did a bunch of updates and was forced to reboot.
At this point I get a '\windows\system32\config\system is missing or corrupt' message.
So... after pulling out my hair during a day of troubleshooting [I called in sick] I discovered that there is a rather silly fix for this problem. A temporary fix anyways.
If you get this error message, turn off the computer. Set the CMOS jumper to blow away the BIOS. Set it back to default. Turn on the computer and press F1 if necissary to continue.
Boots up fine.
The funny thing is that the next time you reboot you get the damn error message again, even though the BIOS should still be at default settings.
If you do the 'trick' again at this point it boots normally.
Windows seems to be behaving normally when it is booted up, but it is a real pain in the ass to have to do this every time I want to reboot my computer. Also, I would like to be able to tweak my BIOS and this is forcing me to keep the default settings.
I tried flashing the BIOS on the motherboard and have updated all the drivers... any more suggestions? I miss my ASUS.
Hey Guys,
Boots up fine.
