altec_tech
- Aug 17, 2004
Hi everyone, I am quite upset right now, due to my computer not posting. It was in storage in a plastic container at just below room temperature, along with all the other peripherals. I recently have set it back up in my room and hooked all the connections correctly. I turn on the computer and shortly after I hear a somewhat long beep, then two short beeps, then a somewhat long beep, then two short beeps.
Nothing displays on the monitor. If I turn it on, it says activate by using PC.
My keyboard seems to work though, as in, when I hit caps lock, the caps lock key goes on. It almost seems the computer boots up fine though, it just doesn't appear on screen. I haven't opened my box in awhile.
I also should note that it is a DELL (4400) (and yes I know, I need a new computer trust me) It's an Intel with 2.0ghz and 768mb of RAM.
I researched a lot of places, and I think it could be a memory problem, but I'm not sure.
Could anyone help me out with this problem? Any reccomendations are diagnostic tests I should run? I just don't want to have another repeat, where I have to have some DELL guy OR dell technical service guy help me fix it, then when it's done, it is completely unstable and can't run most programs, or have lost a lot of data.
Please help! I don't want to lose all my data!
Thank you in advance!
