Help please
sl1982
Heres my problem guys.
[21:06:06] Completed 12500 out of 250000 steps (5 percent)
[22:06:14] Writing local files
[22:06:15] Completed 15000 out of 250000 steps (6 percent)
[22:16:31] Warning: long 1-4 interactions
[01:06:14] At least 3 hours since checkpoint written...
[01:08:14]
[01:08:14] Folding@home Core Shutdown: EARLY_UNIT_END
[01:08:14]
[01:08:20] CoreStatus = 7B (123)
[01:08:20] Client-core communications error: ERROR 0x7b
[01:08:20] This is a sign of more serious problems, shutting down.
This has happened on my SMP client twice in a row.
Project 2665
Any ideas?
[01:08:14]
[01:08:14]
Project 2665
Any ideas?
If everything was working ok and now it's not you are left with two choices.
Drop your overclock and or clean out your HSF. Sometimes they are actually supposed to do that (honest) but almost never 2 in a row.;)
No overclock. Stock speeds (on laptop)
Temps check out in the mid 40's when folding
sometimes when the smp clients screw up on me, i just delete the whole thing, and re-install it from stanford. :D
If you got a bad work-unit and it errored without sending any results back to Stanford, then you will try to crunch it three times before you get a new work-unit.
Stanford does not know if it errored out or you had a bad download, so they download you the same work-unit a couple of times more times.
Look up the Projct ( Run, Clone, Gen) numbers in the log file.
If they are the same then your still crunching the same work-unit.
So just keep deleteing the Work folder and queue.dat file untill you get a different P(R,C,G) number.
Also you can check over on the folding forums if this is a known bad work-unit.
Luck ............. :D
It was the same WU. Deleted the queue one more time and it gave me something new. Thanks for the help. Dannifood4less appreciates it ;)
LOL, i suggested the same thing he said too, lol he just knows the ins and outs of why. :D
-but yes i do appreciate it.. :D ...
woot! broke 10K again today.. almost 11k actually.
Woot fahmon is now showing 4700 ppd plus whatever my ps3 grabs in a day. Around 800 i think
