Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a only 2 pins for Power LED, but my case has a 3 pin connector, so I have to move one pin over, I tried using tweezers but can't get the wire out. Any help?
on the back of the connector there is a little latch you can lift with a needle to unlock the connector from the casing. Then just move the wire to the location you want and it will snap back in.
Turn the power connector over so your looking at the side with no writing on it. You will see some grooves in the connector, and in those grooves there are little "latches" that need to be pried up with a needle or pick, and once that is done you can carefully pull the wire out of the connector.
