Help please !
rickbmb
I don't know what to do anymore, my pc just can't play any video file. When i open one with any player, the cpu goes to 100% and the only thing i can do is reset the pc.
I can run any games without problems, bf2 or oblivion run just fine.
I tried clean installed nvidia driver, reinstalled nforce driver for my mobo. I tried codec cleaner utilities and i even bought a new video card cuz i was getting really mad :(
One thing i noticed tho is that my card is AGP (7600gs) but if i go into device manager and look at properties on my video card, under location it says PCI bus1, device 0, function 0.
I tought that might be my problem but reinstalling nforce chipset driver didn't change anything, still says PCI bus 1.
Thanks
try installing all in one video codecs...
nothing a format couldn't cure but that should be your last resort...
I tried installing different codec packs but didn't work, Now i'm trying to find a way to remove ALL codecs as i've installed quite a few trying to fix this. I don't know where all those codecs go but most of them aren't even in the add/remove program list.
I also tried a bunch of players and even lower version of media player and quicktime.
just reinstall new codecs on top of the old... Shouldn't have any problems...
Don’t know if this helps. I have this problem with FFDshow from time to time. A ‘re-install’ works for me every time.
I've just installed VLC wich has its own codecs built in and it works !!
Now is there a way to remove all those codecs that don't even show up the add/remove list ?
Thanks
