Help Please !!
vinceboi
i just instaleld the omega driver for nvidia and i restarted and when it boots up past the loading part on the screen it says out of scan..and i cant do anything bout it i even plugged in my bros moniter becuz the resolution goes higher (1280x1024) and mine only goes to 1024x768 ahhh this is so gayy pleas help!!!
Try booting into safe mode and changing the settings.
And please use a more descriptive, less loud title.
uhh how do i get to safe mode? hehe on windows xp sorry bout the caps. but yeah i just reformated and dled and installed the nvidia omega driver and restarted when it finished and as it was loadin up...just as it finished with the loading bar my screen goes blank and it says OUT OF SCAN
Well, you're not pressing F8 hard enough!
Just keep pressing that, starting from the second you press the power button. Don't stop pressing it.
