Help please...
The Other
I have the system down below.. but I went to Fry's and picked up a Celeron D 326+ 64bit, This is my first time with a intel system... The Mobo is the ECS p4m800pro-m
Should I just replace it with Celeron with the AMD will I see a performance boost or be the same. I do mostly gaming I will keep everything if I switch...
If games are your thing, please go with AMD.
The Other said:
even if i overclock it?
I heard these things can get up to the 4ghz range?
I Game just as well at stock speed though. I use Intel and AMD processors. My Gamer Rig is AMD and my HTPC is Intel.
