I recently put together a new build using:
Intel® Core 2 Duo Processor E6300
Intel® Desktop Board DG965WH
Microsoft* Windows Vista* Ultimate/ Windows XP
I've read the [h] FAQ so hopefully my post will be quite straightforward
One weird thing I noticed is that on computer POST, there is no image screen whatsoever.
The BIOS does start if I hit DEL, and it does announce the option to boot to disc if I have one in the drive.
Everything went fine with the install of XP Pro. I was even able to install all the Intel Drivers for Video and Ethernet on the included driver disc.
I tried to turn it on later that day and the XP load screen would show for about 2-3 seconds and then the computer would just shutdown.
Computer boots in safe mode no problem
I tried a new HD, and used both Vista and XP to the same effect...Install no problem, and then shutdown on load screen.
Steps I've taken:
- Symptoms initially made me think it was overheating. Double checked fans. Have a total of 3 in My Coolermaster CAC-T05 case.
-Reseated the Heat-Sink Fan using Arctic Cooling MX-2 Paste
-Tried both a 450W, and 550W Antec PSU (Both worked fine in previous builds)
So there we go. I am completely stumped. At this point I can only think it might be some video driver issue. But like I said it worked fine at one point. Perhaps I should try a PCI-E video card instead of onboard?
Thanks guys, any help would be much appreciated
-Fellows
Steps I've taken:
-Fellows
