Badger_sly
- Mar 20, 2002
Hello and thanks for any help up front.
A friend of mine installed SP2 beta without SP1. XP acted real strange then he called me. I told him to use the Add/Remove Programs on the Control Panel to remove the SP2 beta (as per MS website instructions). All was going well, was uninstalling, until his computer lost power, or shut down for some reason.
Now, when starting up, it gets to login screen barely, but immediately reboots every time. It reboots when trying to go into Safe mode, and it says it can not go back to last know good configuration because a file is missing.
We have gotten to the Recovery Console, but he had to go to work. Should we run "fixboot" or "fixmbr"? He is trying not to lose data which is on the drive.
