KezzerDrix
- Oct 7, 2004
Hello,
The motherboard I purchased has a 24 pin connector and my powersupply is only 20 pin. I went to buy an adapter and read that you dont need the adapter that the 20 pin connector would work? I cant find any information in my motherboard manual. Can I use the 20pin connecter in place of the 24pin? If so what functionality would I be losing.
Thanks
Kezz
Thanks
Kezz
