Help please!! overheating NB?
henryabooboo
Ok, so heres my story.
I thought it would be cute to build a mini-itx gaming rig. I like the minimalism in lian li designs so i opted to use a lian li pc-q11... i am also an AMD fan boy so i got the ASUS M4A88T-I Deluxe board to go with it. Firstly i used the stock cpu cooler but really wanted to give the corsair h50 a shot so i installed it today...and now my computer auto-restarts because it says my north bridge is overheating...i do understand that NBs tend to get hot and i have the threshold set to 95c. 95c should be blistering hot...but when i touch my NB after the computer decides to shut itself down it's no where near hot, i wouldn't even say its warm. Can anyone help me with this please?
Here's the specs:
Lianli PC-Q11
AMD Phenom BE 555 x2
XFX 6850 BE
OCZ 600w modular PSU
OCZ agility 2 ssd
I have the bios set to stock voltages (basically everything i default.)
The computer decides to restart itself within 4 minutes of me turning it on
oh and btw, the computer functioned flawlessly before i installed the H50...
and also can someone recommend a good temperature monitor? i havent fiddled with computers for a long time...the last time i did motherboard monitor 5 and sandra were cool lol
any help is appreciated!
o...and i wasnt completely honest in the first post lol...i tried to unlock my cores but after doing so it didnt even boot windows, so i tried disabling the 4th core and it booted up, i checked control panel and it still said it was an x4! that was when it first restarted itself and posted NB overheating...i quickly reverted back to default settings but this NB issue still persists.
blah problem sovled. h50 was screwed on too tight...and i did successfully unlock to x4. forgot unlocking 3 cores actually means i have 4 cores running lol
ill bet the temp being reported is cpu temp..you still have a problem with your mounting if it straightened out...you better pull the mobo and very carefully remount it and only put moderate pressure on the cpu...and not too much thermal paste either....
