Ok, so I built this Core i7 system that I posted earlier, and everything is completely screwed in and perfect overall. When I start the system though, I never get a video signal and the computer does one long beep, then two short ones immediately after. I have read online that this means there is a video problem.
I am pulling my hair out w/this now. I have the MSI X58 Platinum Crossfire MB, with an Nvidia GTX 280 video card that was just working fine two hours ago. I know I can't do SLI on this board, I don't care about that, but the single card should work just fine. I have used a power supply 8 pin and 6 pin together, no luck. I have used a 6 pin and an 8 pin converter that has 2 six pins (like I did with my last setup), no go. I have switched around the 6/8 pin configs back and forth trying to figure this out, no go. Finally, I've reseated the damn thing about 10 times now and I cannot for the life of me get this damn thing to show a video signal.
Does anyone here have any suggestions? Should I try the 2nd PCI-E 16 slot or would that not work? I really need help asap, I'm getting so damn fried out on troubleshooting this after two hours now. I should be installing Windows
