help please keyboard won't work....
jordan172005
I just put together a new system....
Pentium 4 2.8ghz/512k/533mhz Northwood
Asrock P4v88+ Motherboard
2x 512mb Nanya pc2700
Aopen FX5900XT 128mb
2x 40gb maxtor 7200rpm hdd's
1x DVD +- RW
Now I have a problem that I can't figure out. I put it all together and the keyboard will not flash or work at all. everything in this system is known working as I'm using everything now except for the motherboard and processor. I tried booting the computer with my 40gb maxtor which has an Xp install on it and it gets to the welcome screen where it asks for my password without a problem but I can't type !! I also cannot enter the bios or anything because the keyboard does not work at all. I have tried 2 keyboards ( one PS2 and one USB ) and both work on other pc's but not this one. Does anyone know if there is something I need to do ?
I've been dying to get these parts and now they're here and I can't use them. Someone please help.
put the keyboard in before you reboot the system maybe.
I had someone try to switch them out for HOURS before i told them that :p
