Help: Play PS2 on my computer
chaokai
To begin with, I use ATI All-In-Wonder 7500 card for my set up.
Hooking it up is not a problem but how do I manage to get the picture on my screen? Using some kind of program or something I guess?
I haven't done anything like hooking up an external app to my video card so I have no knowledge of this whatsoever.
Thx
you dont need all that. It doesnt matter what video card you have. If you want to play PS2 in a MONITOR, you must get a VGA Adapter that will allow you to play using the monitor.
The AIW cards should come with a TV viewer software. if you don't have it then goto www.ati.com you should be able to download it from there.
Originally posted by thebro
if you watch tv there is a setting in the app to choose the input.
Yes, just right click and instead of choosing the cable choose "composite".
I did get to the tv menu and select "composite" and it worked!!!
Thanks all for your inputs!!! :)
i went to radioshack and they never heard of it. where can u get these at?
That's funny... You seem to be under the impression that the salesmonkeys at Rat Shack actually have a clue about what they sell...
