I'm working on slowly building up a storage server, and planning on running ZFSGuru. I have some pre-exisiting hardware that I'd like to use, and just make a few changes. My current hardware is as follows:
AMD Athlon II X2 245 @ 2.9GHz
MSI 785GM-E65
CORSAIR CMPSU-400CX
OCZ 2GB DDR3 1800 (PC3 14400)
That's all thrown in a simple tower at the time being. Eventually I plan on putting it in a rackmount enclosure, and putting it in a cabinet along with a couple other things.
First things first, I'm going to throw in either 4GB or 8GB of RAM (Opinions on how much is really necessary?), as I've been told numerous times that ZFS likes its RAM. I plan on dropping the voltage a tad, and maybe underclocking the CPU a bit, just to cut down on power usage. I'm also going to throw in an Intel Gbit NIC.
Next, I'll have to do something about the storage. I'm kind of torn between a few options at this point in time, so I'm looking for some input. I'm looking for decent performance (enough to hopefully saturate my Gbit network, ideally, but it's not a huge deal as long as I still have good performance), while also having some redundancy. RAID-Z seems like a good option. The setups I'm looking at are as follows:
Samsung F4 320GB x 4 in RAID-Z
Total Usable Space: 960GB
Cost: $175.96
(Score: 953)
Samsung F3 500GB x 3 in RAID-Z
Total Usable Space: 1000GB
Cost: $164.97
(Score: 887)
Sam. F4 2TB x2 in MIRROR
Total Usable Space: 2000GB
Cost: $199.98
(Score: 881)
The scores are just benchmark ratings off some random website, just to help me compare performance between drives. The first option is the fastest drive of the 3, but the smallest, forcing me to use more disks. The second option is a good middle ground, giving good performance and a good amount of storage. The last option gives lots of storage, but less performance. I don't really need a whole lot of storage, but I'd like enough that I don't need to upgrade in the near future. At the time being, my data collection is only about 300GB, but as mentioned, I'd like to leave some room to grow (which it will with time).
Another thing is what's happening with the ZFSGuru OS itself. I want to do a proper install rather than running a LiveCD. As far as I know I'm able to run it off of a USB drive, or install it onto the ZFS pool itself. I'm not sure if this is the case, so correct me if I'm wrong. Is there an advantage to one or the other? Also, I've seen people add SSD's as a cache to improve performance. What kind of storage and performance does the SSD need to have? Am I able to add this after the fact, or does it need to be done during the initial setup?
So that's pretty much all I have at this point in time, although I'm sure I'll come up with more questions. If anybody has any advice pertaining to this build in general, I'd love to hear it. I'm looking forward to getting this thing up and running.
Thanks,
- Jesse
MSI 785GM-E65
CORSAIR CMPSU-400CX
Cost: $175.96
(Score: 953)
Cost: $164.97
(Score: 887)
Cost: $199.98
(Score: 881)
Thanks,
- Jesse
