First off, I think this is the correct forum for this, but if it is not, mods feel free to move. And Thanks for your help in advance, and sorry for the long read, I tried to organize it into something other than a wall of text.
I have established that my current router, is inadequate, and I have long wanted a UTM, so I have decided to make my own router.
Initially I was planning on using an old p4 pc, but when I went to play around with Sophos, the hard drive crapped out, meaning all I can reuse now is cpu and motherboard (maybe ram).
I do not want to dump any more money into that pc, especially since it was the bare minimum system requirements for Sophos.
As far as usage, I received a free upgrade to 20 or 25 mbps internet from my isp recently (can't remember which). Point being I don't need anything crazy for bandwidth, latency is more of a concern.
Priorities for this build are as follows, from most to least important:
Low power- main reason I'm ditching my P4 (it outpaced my gaming rig as far as idle power)aside from money. I would like to keep idle power of this at 30 watts or under. The lower the better, also I do plan on undervolting to achieve more efficiency
Low Cost- 100 is max budget, but I would prefer to keep it around $50 for core components (mb, cpu, ram)
Expandability- This entails the motherboard having multiple (at least two) pci-e or legacy pci ports for nics. And possibly a third for wifi cards. Also I would like bios features such as undervolting.
Parts I need help picking out:
I mostly need help choosing an energy efficient socket for a basis.
I was thinking of using 775, am2, fm1, or I would stick with 478 if someone can suggest a cpu which is efficient. VIA is not out of the question either, but I am not that familiar with their designs.
All suggestions will be entertained, including atom and similar amd designs.
Two NICs- I want something with good latency. If I use legacy pci, they will be 100mbps card, pci-e will be gigabit.
Wifi- If it's a card, it must be wireless N. Although, I dont actually know if I can use an internal card as an AP with any of these os.
If I can not I would like suggestions for routers or APs which work well for this purpose.
Other parts I plan on using, but have an idea what I want:
PSU: something 80+, either a pico psu or CX430 or similar
RAM: at least 2gb, dependent on socket I choose
Hard drive: at least 30gb, I might use an ssd, cf card, usb stick.
Network switch: already own an 8 port gigabit.
Parts I will not need:
Case
Video card
Sound card
Disk drive
Any additional add-on card
I plan on using Sophos or Untangle as my OS, but its not 100% set yet.
I also plan on buying everything used, as it is mostly out of production, and I live in the US.
I do believe that I answered all the questions from the general build guide. If there is anything else you need to know, do not hesitate to ask.
Thanks again!
Case
Video card
Sound card
Disk drive
Thanks again!
