Help, PC turns off 1-2 seconds after booting
Breydel
I just put together a new gaming computer with the following components :
case : Antec Sonata III (PSU : EarthWatts 500W)
cpu : Intel Core 2 Duo E8400 3.00GHz 1333 6MB Box
cpu cooler : Cooler Master Hyper TX2
mobo : Asus P5K-E/WiFi-AP iP35, SATA2 RAID, WLAN
mem : Corsair 2x2GB DDR2 SDRAM PC6400 CL4.0 DHX
hd : Samsung 500GB SATA300 16MB, HD501LJ
dvd-rw : Asus DVD-/+/RAM 2014L1T 20x/20x/14x LS Retail
video : ASUS EN9600GT/HTDI/512M Geforce 9600GT 512Mb DDR3
lcd screen : Samsung TFT Monitor 2232BW 22", DVI
os : Microsoft Windows Vista Home Premium 64bit UK OEM
Sound : Creative Labs X-Fi Extreme Music
Keyboard : Logitech G15
Mouse : Logitech MX510
The harddisk is connected to SATA-1, got SATA power connection too.
The DVD-RW is connected to SATA-2, got SATA power connection too.
SATA-1-4 are master btw, SATA 5-6 are slave
The problem then:
When I switch power on and want to boot up the PC it seems as if power is on for 1-2 seconds and is then automatically switched off again. All my fans (PSU fan, CPU fan, case fan) are on for 1-2 seconds and powered down again. Also the LED in front of the case and the LED from the DVD-RW drive are on for 1-2 seconds and then off again as well.
My mobo has a green LED on it as well which does stay lit all the time. (it’s a LED to indicate there is power on the mobo, even in sleep and “soft-off” mode)
This problem happens both when I push the power on button but also when I press and hold it. If I release the power on button and press it again, power seems to be on the system for 2 seconds again before turning off again.
I did test my PC with the side plate from the case still removed but that shouldn’t be a problem right?
Also the PC doesn’t even give any beep errors. Everything seems to be powered up for 1-2 seconds and then powered down again. But of course BIOS beeps usually occur a bit later, more like 5 seconds after you switch on a PC.
Could really use some info about what could be wrong. Perhaps I have a dead motherboard?
Anyway it seems to be exactly the same problem as what was described here as well :
http://www.hardforum.com/showthread.php?t=1279966
He found out what the problem is but didn't say what it was. :(
Nevermind, found the problem myself. One of those "duh /blush" situations.
Apparently I forgot to connect the 4 pins 12V connector from my PSU to my motherboard. I thought the big one (24 pin?) was the only one needed. :)
well now you know forever. I do have to say good on ya for saying what the mistake was!
Cheers and enjoy that new machine it should do nicely!
I have the 4x4 12v plug on my powersupply and at first I was confused on whether or not I should take it apart and just use the 2x2 plug or both. My motherboard had a cover over the 2nd set of four so I didn't know if I should use both.
I figured why not and plugged in the full cable and haven't had a problem with the system yet.
