Ok I have a question that I hope some one could help me with
I wanted to wire 3 120mm CCFL case Fans in Parallel and have them hook up to a single DPDT switch so the can be adjusted from 12v-7v. Would this work even though the fans also have CCFL on them?? Also will this switch be able to hold the that many fans and ccfl's?
Link for Fans
http://www.jab-tech.com/Logisys-120MM-WHITE-DUAL-CCFL-RING-FAN-pr-3109.html
Link for Switch
http://www.itcelectronics.com/produ...=3648&osCsid=9f750a9627352c33c80f4a5d2d8f342b
Thanks!!
Link for Fans
Link for Switch
Thanks!!
