MODS: feel free to move this is if there is a more appropriate forum.
Earlier tonight my computer shut off randomly and when I restarted about 10min later, it told me it had shut down due to a CPU overheat.
A little backstory is in order. This is an intel 820 on a D945PSN mobo with ATI x1800xl. The case is a Thermaltake xaserV which has 3 intakes (2x90mm on a side panel, 80mm front) 2 exhaust (80mm blowhole 90mm rear). All cooling is stock, and no overclocking (not that this board will really let me). The CPU cooler has never made any strange noise and was definitely running at the time (case comes with a fan controller which shows temp / fan rpm). There is nothing loose in the case which could have physically stopped the cpu fan.
At the time of the crash it had been on all day, as it normally is, and WoW had been running for about 5min. Performance was normal, fans were on full blast, ambient room temp was normal.
This system has run BF2 for well over 3hrs with no issue, along with WoW, FEAR, Oblivion, and whatever else you can think of. All applicable drivers / bios updates have been applied.
Also, all parts were purchased new (no refurbs) around this past Christmas. CPU / mobo from intel through Retail Edge, same deal with the video card, everything else from newegg.
I'm typing this post on the computer in question, and everything *seems* fine, I'm just concerned. This system has had no problems until this point and it seems odd that it would suddenly overheat under a relatively minor load.
So... should I be worried? Freak incident? Dying CPU fan? Ever seen something like this? Any input is greatly appreciated.
