Help overclocking my system
stripe123
Hi,
I was wondering if someone could explain something for me?.
My current setup at the moment is as follows
CPU Multi 20X
BCLK 200
QPI X36 =7200mhz
Uncore 3600mhz
QPI voltage 1.4V
CPU Voltage 1.35V
Dram Voltage 1.66V
Dram speed 2000
First question is, 2000mhz or should I do 1600mhz with lower timings
second question is, what program can I use to test QPI\UNCORE\DRAM stability
third question, I believe the highier uncore the better performance, I have heard you need your RAM half the speed of your Uncore to prevent bottle knecking, is this true? I have tried and tried to get a 2:1 ratio but cant closest I can get at 3600mhz uncore is either 2000mhz or 1600mhz ram due to the fact the god damm uncore multiplier is stuck at 18x and cant be changed in the bios which does not allow me to tweak or get a 2:1 ratio.
cheers appreciate all help,
have a great day.
Jamie
