Help overclocking my laptop!
AZBOOSTIN
Hey guys decided I wanna try to boost my laptop alittle bit, Im looking to get some more performance in games ect....
Msi - based mother board... MS-16F2
Processor i7 2720QM
Video GTX 560M
memory ddr3 1800 mhz..... 16 gb...
any software that will let me max this baby out... it is supposed to have top notch cooling in it... what are safe temps for my cpu/gpu
Not possible, unless you can find a custom bios (extremely unlikely).
like tsumi said, it isn't possible with the processor since there is no way to get access to the multiplier.
as far as the GPU goes you might be able to by using MSI afterburner.
I wouldn't if I were you. Most laptops just don't have the cooling / air flow to overclock. Maybe one day they'll have water cooled laptops.
cant o/c laptops the companies who make them dont put in a bios like your home pcs mobos
If you want more performance in games, then OC the gpu. You can OC it with MSI afterburner. You should be able to get about a 15% OC on the gpu without too many issues.
