i just gotta dfi lanparty ultra-d, and im having trouble gettin a good oc on it....theres soo many options i dunno wut to change...
this is wut im running
3000+ venice
stock amd cooler
corsairxms cas 2
x800xl pci-e 256mb
i got the chip oc'd from 1.8 to 2096mhz (almost 2.1ghz) this is @ 230fsb, anything over 230 i cant load windows...i dont think im facing a heat issue (cpu is @42-underload, case @42) the only changing in the ram settigns i made was to change the cas to 2 (it was defaulting to 3)...im a newb to dfi boards so any help would be appreciated...if im missing any settings info lemme know and ill get it....thanks
o yea the overall timings on the ram currently are 2-3-3-8 1T
o yea again im using the 3/10 bios
3000+ venice
stock amd cooler
corsairxms cas 2
x800xl pci-e 256mb
