Help ! Oveclocking MSI 7900GTO
Redmanc
Ok i have a MSI 7900GTO which I'm trying to OC with Rivatuner. I am using Nvidia's 93.71 drivers.
I know what I'm doing with Rivatuner but for some reason i cant save my clocks. So therefore when I reboot computer it goes back to manufactures clock speeds.
The only other program i have to OC GPU is the Nvidia's program which when clock using that also does the same. I have have also uninstalled Rivatuner and just used Nvidia's program to OC and still it just goes to manufactures speeds.
Any help please on how i can keep my clock speeds on reboot ?
this I believe was a BUG in those drivers. If I was you, use the 91.47 drivers from nvidia, and you should be good to go.
Why not use coolbits? It works on 93.71 drivers just fine, as im doing it this moment.
