didnt notice that, if i install windows 7, can i upgrade to windows 10 anymore?(planing on fresh install). Can you format the windows disk?Your title is the wrong way around.
Generally I recommend a fresh install otherwise just use some cloning software. Acronis worked well for me in the past.
but my windows 7 key is the disk, and if i install w10 in ssd, it's gonna be 2 w10in that case you can just install w10 and it will activate itself. w10 activation is tied to the hardware and it should be automatic. if not just input the w7 key if it asks for it.
i got everything working, i got windows 10 on it too.im going to disconect the hdd to eliminate the 1st windows 10.thanks btwyes if you leave the hdd connected you will get a dual boot option for the old and new install.
just disconnect the hdd until you have the new 10 installed on the ssd. when everything is running correctly you can reconnect it and reformat it.
MS now attaches the keys to you MS account and the hardware so it should just reactive.
do you not have your 7 key sticker?
