Need help optimizing cpu on my PC. Not wanting to overclock, just want to get all I can out of the cpu without overclocking. Months ago I had local shop upgrade my MB to a P4 2.4gz, and it's been running fine.
Recently I ran SIW and now I see it seems I'm not getting all my cpu potential. Here is what I have, as reported by SIW:
MB
Model...................P4X266-8233
Chipset Model...........VT8753 Apollo P4X266 System Controller
CPU
CPU Name................Intel(R) Pentium(R) 4 CPU 2.40GHz
CPU Code Name...........Northwood
Technology..............0.13µ
Platform Name...........Socket 478
CPU Clock...............1772.42 <-- seems low
System Bus Clock........393.87
System Clock............98.47
Multiplier..............18.00
Original Clock..........2400.00
Original Bus Clock......533.33
Original System Clock...133.33
CPU clock at 1772.42 seems way too low, especially with a P4 2.4 installed. I went into Award bios (2001) and found that CPU Clock was set at 100. It lets me adjust from 100-132, so I tried 132 and sys would not boot. The highest I could set it for was 115. At 115 SIW reports:
--- at 115 clock ----------
CPU Clock...............2057.84
System Bus Clock........457.30
System Clock...........114.32
If I set it higher than 115 I have boot problems, windows crashes at 116-120. Higher settings cause bios to not even boot. At 115 SIW reports 2057 cpu clock, which is better than previous 1772. How can I get it to max of 2400? The MB manual says in specs it's a 400MHz system bus. Yet SIW reports "Original Bus Clock=533.33" Which is it, 400 or 533? Is this the max for my mb? I think so, but want help/comments.
Thanks for any help.
MB
CPU
