I'm really sorry if this is not posted in the correct section!
I've just pieces together a new rig for crysis with everything working perfectly fine. However there is one little problem I cannot seem to figure out. Every time the HDD led goes red there is this noise that comes with it... which sounds like a rodent biting its teeth on a sheet of metal... I've not heard this noise since I had my first Pentium system. If i'm to guess I'd say that noise is sync'd with either my cpu or hard drive read/write processes... the question is... How do I get rid of it? I've tried removing the led.. speaker.. and all those front panel wires but still no luck. Anyone know a way or which component makes the noise? Thank you.
