I run win7 x64 ultimate and got duped into the acronis 2010 upgrade
I say duped as the marketing material implies that you can back up to a vhd file and then simply use that vhd in virtual machine. This is not the case, yes you can make backups to a VHD but can only use for backups or (what I now deduce) boot from them seperately
My problem is that I need to run XP for work apps and prior to this have been dual booting. I got around some software by being able to run it fine inside of a 'normal' XP mode VHD from win7, but I can't do the same for another must have software suit - deidicated work apps.
So, anyone know how to modify a VHD image of an existing XP hardrive so that it can boot and run within win7 virtual PC? I'd love to think someone has being able to do this
By the way the acronis 2010 is a nice upgrade from last release, just annoyed at the way i got suckered. I always use them anyway, so wasted time not money.
(I'm new to vitual machines)
