help on this build
dojugoo
x-dreamer - $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144001
xclio goodpower 500w power supply - $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
AMD athlon 64 x2 5200+ - 162.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
geforce 7600gt - $94.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130062
gigabyte am2 mobo - $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128034
corsair xms2 2gb - $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145015
is there something i should change about this, im going for budget so anything around this range is fine, but lower would be better, and gaming is not really a concern
An X1950 Pro will treat you far better than the 7600 and should cost much more. Save money and get a less expensive case if you have to.
For budget, everything else looks ok.
I'd switch out that mobo and CPU for a P965 mobo and a 4300 for the CPU. Do a little OC and it will beat that 5200+. For the case I highly recommend you go with a case that only uses 120mm fans, my current case has an 80mm fan and it is LOUD.
