Help on Q6600 OC
samtan
Hello
First time to get into overclocking , i have Q6600 processor with asus maximus x38 , my target is 3.2 Ghz for a start. cooling with zalman 9700 fan
here comes the noob question :eek:
i ran prime95 and i had 1 error on the 4th core after 1 hour while other 3 cores ran fine till i stopped test after 3 hours , is there something wrong with my 4th core or is it just that when 4th core went off after error more juice went for the other 3 cores so no errors happened?
Thanks in advance
It usually means your overclock is unstable. Please list your system specs & tell us your bios settings. My first impression tells me you're under volting the processor.
Bios setting i changed
FSB Freq 400
CPU Ratio setting 08.0
CPU Voltage 1.32500v
North Bridge 1.43v
Bios readings
VCORE 1.280v
North bridge 1.456v
CPU PLL 1.632v
DRAM Voltage 1.968v
FSB termination Voltage 1.456v
South bridge voltage 1.072
C2Q Q6600 VID 1.300v L731B / Zalman CNPS9700 fan / Temp ~33 idle , ~53 load
Mobo: Asus Maximus (Bios:1207)
Graphic: eVGA 8800 512 GTS
Mem: 4x 2GB Corsair CM2X2048-6400C5DHX
OS: Windows Vista 64
http://valid.x86-secret.com/show_oc.php?id=452735
You should increase your v-core to stabilize your o/c. I would raise it one increment at a time & then run Prime to test its stability. If it fails, re-boot, increase your v-core & test again. If Prime runs a few hours without failing, you are in good shape. Keep an eye on your temps. I would try to stay under 72C.
