Im going to start watercooling mainly because i OC and i want a quiet system, been OCing on air for a while, and i get good results...but with a lot of noice.
I plan to cool CPU, GPU, Chipset + Hard Drives with the WC setup.
My main concern is the Pump, ill use a heatercore (or 2) as my radiators with a couple of 120mm fans:
In case of 2 radiators (heatercores)
(Pump --> CPU --> Chipset --> Radiator2 --> GPU --> Hard Drives --> Radiator1 --> Reservoir --> Back to pump.)
So, what kind of GPH and max head will i be needing for this?
Im looking at a Via Aqua 3600 rated at 1057gph at 0 head and with a Max head 11ft.
What do you guys recommend?
