Back_Packer
- Mar 20, 2003
I need to upgrade due to getting a dell 2005FPW monitor. I don't think my computer can game with the higher resolution. What I have is a..
Athlon XP 2500+
ATI 9700Pro
GeIL Value 1GB http://www.newegg.com/Product/Product.asp?Item=N82E16820144310
Antec P180
400w power supply http://www.newegg.com/Product/Product.asp?Item=N82E16817159023
So I will be reusing the p180, memory and maybe the power supply (?)
So I need a motherboard, cpu, video card, and maybe power supply. I would like to be able to game at 1680x1050 resolution.
I don't have the much to spend though. about $500 ??
I would like to go the 939 route.
Also with the p180 case I need a PS with long cables.
Thanks
Athlon XP 2500+
ATI 9700Pro
Antec P180
Thanks
