I hope to get this project finished by Christmas for myself, I am trying to keep costs under $700, but if there is a part worth the extra cash, I wont hesitate spending a little extra. Primarily a gaming PC, I hope to get into some of the new FPS games on the market and I hope this build to be upgradeable and I will probably take a dip into overclocking the CPU under stock cooling, nothing hardcore for this build.
Anyways I am going intel, specifically E8400
The mobo I was looking at a couple weeks ago seems to be disappearing from websites, it was the GigaByte GA-P35-DS3L which I got from recommendations of good stability compared to the newer chipsets. Since this board looks like it is discontinued, what options do I have?
I am looking at the EVGA 9800GTX, that is pretty much a final decision unless someone can object with good reason.
Ram I am confused on, Initially I want 2x2GB sticks, but PC8500 or other? How do you know what to buy for ram? what do you match?
As for a HD, this seagate seems like a no brainer at this price, am I wrong?
http://www.newegg.com/Product/Produ...1c3grabb3r-_-Hard+Drives-_-Seagate-_-22148335
Case will most likely be the Antec 1200 unless there are any suggestions for something similar, I don't like doors on the front and prefer it to be black.
PSU I am still up in the air, when thinking of being able to upgrade I am going to need power in the future, but I'm not willing to drop $100+ on a PSU right now. The antec Basiq 500W is $30 at microcenter, and I figure by the time I need to get more wattage I could probably find a 750W for $30 2-3years from now. Smart decision says get the $30 antec, guy tells me get the 650W antec earthwatts for $65
Optical drives are irrelevant, too inexpensive to bother discussing, I'll just got for something popular on newegg.
Soundcard...Lil confused there, I only use headphones on my computer, $50 sennheisers, does it really matter? Will I notice a difference between a $25 soundblaster and a $50+?
OS...I have an old copy of XP Pro I never used and paid full retail for, I guess I'll use that, but it is only 32bit, will I be fine with that? I didn't plan on getting a new OS until windows 7 is released.
I believe that is about all, am I missing anything? Suggestions welcome with good reason (price/quality).
