Help on diagnosing POST failure (P8P67 Pro)
Zontar
Last night, I went to bed and my computer suddenly shut down on its own. When I attempted to start it back up, the machine failed to boot, and the motherboard lit up the red CPU LED. I pulled all but one RAM module and the machine still doesn't POST. So, I'm thinking it's one of three possibilities: the power supply went, the motherboard went, or the CPU went. But I don't have any other systems to cross-check most of these components and figure out which to RMA (everything is new enough to be under warranty.) I *do* have an old 2006 era system that I can test my PSU with, but that's it.
Adding to my fears is that whatever is causing the problem is causing a cascading failure. For example, the PSU might have went bad (it was a good SIlverstone model though so I'm not sure) and took out the rest of the system with it. Or the motherboard might be bad and ruining any replacement CPU I might put in it. Stuff like that.
This is the first system I built and had significant problems with, so where do I begin troubleshooting? What is the recommended order for replacing the components in a failure like this?
Pretty unlikely for a CPU to just go out like that, so I'd put that at the end of my troubleshooting. Have you tried pulling out all the add-in cards as well, or moving the GPU to a different slot? My first P8P67 Pro had a PCIe slot 1 go bad and it wouldn't post with a card in it, but moving the card to the lower slot worked fine.
Edit: The fans are spinning and everything, just the CPU led is on? You've tried resetting the CMOS?
usually if the PS goes, the fans will jerk, then stop...
there is a PS lead called "Power Good", when there is no signal on it, it tells the MOBO its bad,and wont spin up the fans.
I had a Silverstone PSU that failed and did exactly as you describe as to a socket 775 system. Luckily I had another system I could cross check it with. The damn PSU took out the mobo, and a quad core Q6600. I'll never buy another Silverstone PSU.
its been my experience that red LED CPU means bad CPU - lol
just curious - what Heatsink brand/model you using?
(when you ask for help, its good proceedure to have your whiole component list in sig)
New developments:
I've disconnected everything but the main motherboard power from the PSU. When I disconnect the video cards and hard disks, the machine will get farther than the red CPU LED (all the way to throwing a video card error because I have none plugged in...expected behavior.) This gives me reason to suspect that there is nothing wrong with the CPU since I see it pass the test right in front of me when everything else is unhooked.
When the disks and video are connected, the motherboard will alternate between two failure states: it will stay on the red CPU LED, or it will repeatedly shut off in five-second intervals after staying on for one second.
Do I now have reason to suspect a PSU issue, and should I request an RMA for this device first?
I'm using the CM Hyper 212+. Have kept a close eye on temps and was not overheating to my knowledge.
New developments:
Try the video card in the second PCIe slot (the lower one) first. My top slot went bad, and it would hang on POST, but when I moved the card down the board would work fine. At least that way you can keep using it while you wait for a cross-ship RMA.
