Guys,
I am looking at buying a new pc soon and was originally planning on getting a AMD XP 2500+ or 2800+ but then found out they only have a 333mhz fsb unless you overclock (which i wasnt too keen on for now) - which would reduce the theoretical dual channel speed of the ddr400 ram. So i am tossing up between these two systems:
1. AMD XP 2500+ with Epox 8rda3+ mobo with dual channel ddr400 ram
2. Intel PIV 2.8ghz prescott w/ 1mb cache with Abit AI7 mobo with dual channel ddr400 ram.
The intel setup is a bit more expensive but has the 800mhz fsb. Also i can get an ordinary PIV 2.8ghz (ie: 512mb cache) for the same price as the prescott but i assume the prescott is better?!
Which of the above systems would you recommmend?
Cheers for any help
CadniuM
Cheers for any help
CadniuM
