After fiddling with my bios a bit, I OC'ed my 4790k to 4.7ghz/1.280v and it seems to pass 5 minutes of OCCT and POV-Ray (Andtech uses this method to determine stability on their OC's so i follow this suite). On 100% load, I am close to 82c temps but I hardly reach this % so when I play BF4 i'm hovering around 56-60 on load. Now i'm just trying to figure out exactly what options to disable/enable on my bios.
Can someone tell me for devil's canyon, should we have things such as EIST/Turbo/Enhanced Turbo enabled or disabled for 24/7 use? I haven't found a guide that really discusses this into detail. When i check core temp, i always see my clock is at 4699mhz, and at 1.27v core voltage.
