supervette
- Nov 14, 2005
the last computer I overclocked was a pentium 75.
Right now I have a gigabyte knxp with intel 2 ghz. The chip is only 400mhz fsb, I am saving to buy a 3.4 I would like to overclock in the meantime. I'm sure with my air cooling setup that temp should not be a problem. I have a 2lb copper heat sink with a turbine style fan on it that will do about 7k rpms. How should I go about overclocking in the bios?
