Help OCing i5-2500K
lanken123
Been trying the past hour to overclock my i5-2500K to 4.5Ghz. it either fails to boot or gives me a blue screen during the windows load screen. The only things I've changed is
CPU Voltage - 1.25
Turbo Ratio - 45
Internal PPL Overvoltage - Enabled
Speedstep - disabled
C1E - disabled
so anyone know what I'm doing wrong?
full specs
i5-2500K w/ CM 212+
XM3 4GB DDR3-1600
P8P67 Pro
Need more voltage. Blue screens and failure to boot are usually due to the simple fact that you do not have enough voltage to support those speeds.
