one swell foop
- Nov 16, 2004
I've got a:
MSI p35 Neo2 FR,
Core 2 Duo e4300,
2x 2 Gigs of GSkill DDR2 1000 ( stock specs allow 5-5-5-15 and 2-2.1 volts)
2x EVGA 8800GTS 512
Corsair HX520
Cooling is currently via an externally mounted Coolermaster Aquagate. CPU temp probe is broken atm, and coolermaster wont answer my e-mails inquiring about a replacement. Res temp at idle and at 2.7GHZ is31c-34c. Fans are loud-ish and Id like to move to a TRUE or other heatpipe air cooler in the future to silence the system.
I've tried a number of different combinations of settings, most of which end up with left 4 dead shutting down back to my desktop, or prime95 giving me an error on the second core five to ten minutes in. Windows XP pro is stable running non intensive prgrams at the setting shown in pic below.
I have not messed with the southbridge voltage, or the FSB voltage. Haven't looked into what the stock SB voltage is, can't find what the stock FSB voltage is. While the MoBo lets me know what the minimum and maximum possible values are for any given setting, what it considers a dangerous voltage for a CPU or RAM are often common voltages people use for stable and smallish OCs. The settings pictured are ones that give me an error in prime95 and only allow a few minutes game play. I want this stable.
If this was your system, what would you do? I should be able to pull 3 GHz easily out of this chip. Is upping the FSB voltage the answer? If so, where do I start when upping it, how far do I go? Is my processor just shit?
MSI p35 Neo2 FR,
Core 2 Duo e4300,
2x EVGA 8800GTS 512
Corsair HX520
